4age flywheel vs 4agze flywheel
Postby l1ttle_d3vil » Fri Dec 29, 2006 11:07 pm
for a 4agte application, how important would it be to run the larger 4agze flywheel as opposed to the smaller bluetop flywheel or something?
at this stage i'm probably looking at running a modified 4a-t50 bellhousing with a w55 bolted up to it or something, so my only option would be to use a smaller flywheel to fit inside the t50 bellhousing.
it would mostly be used as a street vehicle, with the occasional track day and *ahem*skids*cough cough* .
is the extra few mm of surface area/grab really important or will i be fine with a bluetop flywheel and a heavy duty clutch? i can hopefully knock about $1g off the conversion cost if I can go down this path, so any input is appreciated!
-matt
Postby no_8wire » Fri Dec 29, 2006 11:15 pm
I am running the 212mm Redtop clutch in my 7agte conversion...and all I am using clutch wise is a 3 puk and a very heavy P plate...
I would try find a 212mm one rather than a 200mm one though
no_8wire
Postby l1ttle_d3vil » Sat Dec 30, 2006 7:22 pm
sweet, im pretty sure im running the smaller flywheel at the moment, so might have to get the bigger one. do you know exactly what models they come on? (or at least some models) so i know where to start looking...
cheers.
Postby no_8wire » Sat Dec 30, 2006 7:39 pm
I think its like this:
Bluetop tvis 200mm
Redtop tvis 212mm
Smallport 212mm
Not sure on the 20v sorry
no_8wire
Postby Stealer Of Souls » Sun Dec 31, 2006 1:01 pm
20V are both 212mm also.
but not sure if pressure plates are all the same...
My experience says they are, but not 100% sure.
'86 AE85.5 Levin
Stealer Of Souls
Postby AE85.6 » Tue Jan 02, 2007 4:52 pm
i kept my t50 so i went with a blacktop 20v flywheel on my bluetop,
fits into the bellhousing but only just, then you can use the AE111 clutch plates i ended up using a trd ae111 plate and cover and it works well but standard ae111 plates would still be good.
silver and blacktop flywheels same size i only went with the blacktop item as its roughly 1kg lighter so after some further skimming made a nice lighter rev happy option.
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby TRDGT4 » Tue Jan 02, 2007 5:05 pm
I would have to agree the black top is the (to me) better flywheel
go out and get yourself a black top flywheel and get a heavy duty clutchi.e TRD etc
TRDGT4
