4agze driveshafts? 24spline lsd?
Postby Infinite » Sun Dec 31, 2006 3:30 pm
.l
Lots
Infinite
4agze axles
Postby toyrollin » Thu Jan 04, 2007 10:29 pm
my ae101 4agze axles that come from a e58 lsd are refered to as 11c. the right hand's length is approximately 940mm without pushing the constant velocity joint into the bells, they also have a 24 spline count on the inner and 25 spline count on the outer. the left hand is approximately 640mm in length.
these are also abs type and they fitted directly into my ee90 corolla front hubs. i will check tomorrow the length of the shafts and spline count from a st202 and i guess you want the two wheel drive types because the four wheel drive type right hand axle is a different length
hope this helps
now with dismantled gze
toyrollin
Postby flygt4 » Thu Jan 04, 2007 10:30 pm
ive got ae92 4agze axles for e51 box lying on my garage floor, might look at em for you tomorrow if ya lucky
flygt4
Postby TRD_ZERO » Fri Jan 05, 2007 10:58 am
Yeah id like to know if all the ae92 shafts are all 24spline or are the lsd ones 24spline and the non lsd something else just curious.
TRD_ZERO
