quick 18r question
quick 18r question
Postby Pies » Mon Jan 01, 2007 9:57 pm
will the 18rgu (twin carb model) bolt up to a W50 gearbox that currently has an 18r bolted to it? and will the clutch and flywheel set up from the rgu be compatible with said gearbox?
thanks
Current Rides:
Pies
Postby Jason T » Mon Jan 01, 2007 10:04 pm
Yes.
Same engine family
Fixing Toyota's since '87
Jason T
Postby Snoozin » Mon Jan 01, 2007 10:04 pm
I believe so, friend in Chc bolted his RX30's factory W50 up to the 18RG with no hassles using the 18RG flywheel and clutch.
Was going to use the W55 from the donor Celica Camry but I think it required some mount fabrication.
Snoozin
Postby Pies » Mon Jan 01, 2007 10:16 pm
cheers guys :) topic ends here thats all i needed to know!
p.s. richard.. i was gonna use the w55 outta the mark II :P cbf with ab tho lol
Current Rides:
Pies
