pureadrenalin wrote:143kw is very good for 10psi.
12ish afr is a little lean for my liking, and VERY lean for a stock ecu running 10psi.
pureadrenalin wrote:My old BOV would let go at about 13psi and power wise the car would fall flat on its face and run VERY rich (you could see black clouds in the rear view mirror) and still show 10psi on the boost gauge.
pureadrenalin wrote:I thought if the oxy sensor was stuffed it ran richer.
On a dyno at 10psi, I woud expect your afr to drop off the scale rich (lower that 10:1), so thinking about it, 12:1 is a little concerning.
Change your fuel filter?
You've got an actual boost gauge right? not the stock one?
side note: you can't turn your boost lower that 6-7psi, thats what the wastegate spring is.
vvega wrote:sounds liek your stock ecu is picking up know and pulling all ya timming
ask al all about it
wildcard had it too
could just be a faulty knock sensor
ask al all about it
wildcard had it too
v
IH8TEC wrote:dylan you had 4agze computer aye? did it show up check light when you had knock sensor out? or did you still have it plugged in, just not screwed into block?
1998 wrote:Dont unplug the knock sensor the car will go into limp home mode.
solitaire wrote:1998 wrote:Dont unplug the knock sensor the car will go into limp home mode.
Ah ok... given that the boys at tp says is was knocking a little bit is it likely to be safe to run without it? or do most cars knock every now and again?
Users browsing this forum: Google [Bot] and 31 guests
