replaceing rear breaks ae92 wagon
Postby SkunkWeRX » Fri Jan 05, 2007 12:41 pm
hey guys never done drums before, i need to change my rear breaks,can some one explain how to do it:) before i take them out and get stuck...
SkunkWeRX
Postby Lloyd » Fri Jan 05, 2007 1:30 pm
Pop the bottom spring off, get the handbrake cable off (you'll see where it goes through onto the shoes), then the whole lot should come off pretty easy after that as one piece.
You'll work out the rest after that. Grease the adjuster while its out and apart, wind it most of the way in when putting brakes back together and adjust from there.
Do one side at a time so you can compare if you get stuck
Postby Ae92typeX » Fri Jan 05, 2007 9:24 pm
will probably need to give the drum a bit of a tonk around with a soft hammer also to loosen it up to take off.
Ae92typeX
rear drums
Postby toyrollin » Sat Jan 06, 2007 10:40 pm
there should be two five cent coin sized clips that sit on each shoe, push these in wards and turn one quarter and they will release, then what hrt says
now with dismantled gze
toyrollin
