flygt4 wrote:accessories socket behind centre column/compartment.
if you have anything that runs on 12v or 100v with the same plug you can run it off it.
fivebob wrote:flygt4 wrote:accessories socket behind centre column/compartment.
That one is 100v AC only, the 12v DC one is on the drivers side in the rear compartment. Why on earth they decided to make that one switchable I'll never know.
RunningRich wrote:Would it have enough grunt to run a laptop? That would be handy for ECU tuning.
AJz wrote:just gonna hijack the thread here, has anyone found where the inverter is located, im guessing under the centre glove box ??? If so is it well wired in or quite easy to pull and install a 240V one ???
SuperTed wrote:AJz wrote:just gonna hijack the thread here, has anyone found where the inverter is located, im guessing under the centre glove box ??? If so is it well wired in or quite easy to pull and install a 240V one ???
Its under the Passenger seat in a metal box on my car
