ST215 Headlights
ST215 Headlights
Postby AJz » Thu Jan 11, 2007 10:53 pm
Quick Q:
What type bulbs are in low, high and fogs for a ST215.
im guessing h3's in the fogs, but just wanted to check.
(its too dark and wet outside :P)
Thanks
I had vtax :(
AJz
Postby TWSTD » Fri Jan 12, 2007 9:23 am
H7s for main bulbs (both high and low beams). We can supply LITECH bulbs if you are after that super crisp white look - TS discount applies too :-)
Click here!
TWSTD
Postby Arthanon » Fri Jan 12, 2007 10:10 am
Use
CA1255XU-2 - HELLA for the head lamps (will need 2 packs of 2 to do both main and high beam)
Current Ride: 1998 GT Caldina 3S-GE BEAMS Goodness
Previous Ride: 1994 Curren 3S-FE Not so Goodness
Arthanon
