t3/4 for 4agze
t3/4 for 4agze
Postby ke_25 » Fri Jan 12, 2007 2:36 pm
hey i have a low comp 4agze and am turboing it, i was woundering what trim t3/4 to4es have been knows to work well on the 4ages? or am i beter off going td05 or somthing alike?
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Re: t3/4 for 4agze
Postby Crucible » Fri Jan 12, 2007 7:08 pm
ke_25 wrote:hey i have a low comp 4agze and am turboing it, i was woundering what trim t3/4 to4es have been knows to work well on the 4ages? or am i beter off going td05 or somthing alike?
just type in t3/4 in the search section, and you should get the info your after, there has been mega discussion on this!!!!!!
There are about 4 guys on here that have t3/4s on 4agzes, and a couple that are using tdo5s also, so there is a bit of help if you do get stuck.
sweet
Crucible
Real Life Mechanic
