by atmosports » Fri Jan 12, 2007 9:42 pm
To be honest most of the professional crowds that enlarge/hiflow injectors only give them a small increase maybe 50cc/min maximum. The only ones I've found to be honest in what they flow, be match & have the same flow patterns are some custom ones from RC engineering in the states & I know what they are worth but there was no other easy option in that application. I'd stay clear unless you got some really good machinery as I know I've had a go with mixed results & I've got access to some really good machines/tooling & how how to use it.
There are big secondary options available to suit your car without changing the rail but I can tell you now, last time I priced them a set of injectors & rail kit, plus fitting this setup costs less than the injectors to fit the stock setup & the other good thing with changing the rails was if the 1200cc/min injectors where big enough we could go to 1600/2000cc/min ones for about $200 an injector, where as if we didn't change the rail & 1200's weren't big enough then it would've been the same $$$ again to get the 1570cc ones that were the biggest I could find that'd fit.
