why wont my bluetop fit a bluetop dizzy??? help
Postby shihad » Sun Jan 14, 2007 8:35 pm
i have recently purchased a carby 4age ke26 and i need a dizzy for it, we tried a bluetop dizzy but didnt work.i got told by a mechanic that there is a difference between nz new bluetop dizzys and imported dizzys and that we probly have a nz new one.firstly can anyone confirm what i was told as true secondly is there any other dizzys that would fit as i need my car going as soon as posible so i can take it 2 uni.cheers any info and help would b great :D
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby l1ttle_d3vil » Sun Jan 14, 2007 9:44 pm
how "didn't it work"? what was wrong with it?
Postby KinLoud » Sun Jan 14, 2007 9:51 pm
Are you using the 4age computer to run the distributor?
My understanding (Ihaven't done this!) is that you run the loom, computer and ignitor with the bluetop distibutor to give the spark. You don't need to connect the engine loom wiring to any injectors or fuel pump (obviously).
Hope this helps you a bit.
Ken
Ham
021 408 863
Postby shihad » Sun Jan 14, 2007 10:33 pm
well it was my m8 who tried to get it going as im not 2 clued up with these things but from my understanding the shaft was 2 big on the dizzy.
shihad
Postby shihad » Tue Jan 16, 2007 9:39 pm
bumpty
shihad
Postby big_boy » Tue Jan 16, 2007 9:46 pm
if it was to but i thing your explaneing the difference between NZ new & japa land sharft sizes if so you will need the one to fit your block
big_boy
Postby shihad » Tue Jan 16, 2007 9:53 pm
iv seached the net and i cant find anything on there being different bluetop dizzys? has any1 else had this problem where can i get a dizzy to fit my engine?
shihad
Postby big_boy » Tue Jan 16, 2007 9:57 pm
i think it was only the blue top MR2 motor that were different some one correct me if im rong
on some there was a ring u could remove/add to sute but dont know witch 1`s
big_boy
Postby shihad » Tue Jan 16, 2007 10:01 pm
u legend finally sum answers
shihad
Postby crispy'86 » Tue Jan 16, 2007 10:29 pm
when i get chance i'll measure the shafts on both my nz and import blurtop dizzy's and got an mr2 unit sitn round, can't say i had troubles in the past with different dizzy's. Perhaps the one isn't a bluetop orig. Like did he change the internals to suit the carby application? Igniters and coils are used for efi setups, for carby setup you'll need electonic igniton setup with the coil/igniter asssembly inside the dizzy, #au dizzy with 4k electronic ignition internals would be best bet
crispy'86
Postby Mr Revhead » Tue Jan 16, 2007 10:34 pm
there is no difference between:
aw11 jdm dizzy
ae82 fxgt dizzy
ae82 nz gt dizzy
get a new mate :wink:
more info on how its not working would be good.....
maybe hes just not putting it in properly? try putting some fur around it
Postby big_boy » Tue Jan 16, 2007 10:41 pm
we had them @ polytec & they were different one was 2mm bigger on sharft size & 4mm bigger on the ring were the oil seal is
big_boy
Postby Mr Revhead » Tue Jan 16, 2007 10:45 pm
then it wasnt a bluetop dizzy.
the ae92 ones are a different p/n
so.. there the bluetop one, redtop bigport, and a small port type.
dunno about the interchangibility on them but id suspest they are pretty damn close
Postby big_boy » Tue Jan 16, 2007 10:49 pm
yeah it was both motors look identical just the dizzy`s were different that was the only difference we could find both out of AW11 both same yeah one NZ new & one a japa
big_boy
Postby l1ttle_d3vil » Tue Jan 16, 2007 11:04 pm
i've run bluetop dizzys in a bigport redtop with no problem...
Postby shihad » Wed Jan 17, 2007 6:24 am
well i just found out my bluetop is out of a mr2....
shihad
Postby shihad » Wed Jan 17, 2007 6:27 am
the engine came with an 18r? dizzy and was told that it should work bt we couldnt get it to work.
shihad
Postby big_boy » Wed Jan 17, 2007 9:24 am
why an 18r there points ant they
big_boy
Postby Mr Revhead » Wed Jan 17, 2007 9:26 am
thats why :wink:
Postby big_boy » Wed Jan 17, 2007 9:37 am
yeah but i would be looking for something like a 2E dizzy self contained & eletronic all you need to do is put +12v -12v & set it up in the right place no secprat coil no exrta leads ect
big_boy
