hare wrote:I know it's a long shot,but anyone have a echo/vitz here?I just want to know about the VVTi sensor,do the two wire have power when the car start or it will have power if the VVTi kick in.
matt dunn wrote:hare wrote:I know it's a long shot,but anyone have a echo/vitz here?I just want to know about the VVTi sensor,do the two wire have power when the car start or it will have power if the VVTi kick in.
Um I can only see one wire in that plug?
U sure it's the one for the VVTi?
thaphatty wrote:power in from ecu.....earth through block...... im sorry what was the question
thaphatty wrote:Supposed to have power to solenoid during cold cranking/startup. That I know. And I would assume it would also have power supplied/climbing after a designated RPM to change cam timing.
Definitely shouldn't have power supplied all the time.
(Edit for Clarification) Define: during = While ignition key is on "Start" rather than "On"
pyro_sniper2002 wrote:How are you checking if it has power? With a multimeter i take it? How have you got the multimeter set up. And i would say they would be even more of a gutless peice if the VVT-i was not working.
big_boy wrote:ant they load orranted as well
Crampy wrote:My guess would be that due to it being VVTi, it would be a PWM waveform. It would need it like that to variably change the timing, not like the VVT on 20V 4AGEs, which is just on or off.
