225s on ae101
225s on ae101
Postby bluemaumau » Mon Jan 15, 2007 11:22 pm
ok so i got my new wheels which are 7 inch wide with 225s for the front on 205 for the rear.
i know the 205s fit, but has anyone run 225s on the front of a ae101 before? did you have to remove inner guards, roll guards etc?
Postby aesc » Tue Jan 16, 2007 8:33 am
I'd say they'd fit in there fine. On ae101s the only issue with width is usually in the rear
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Lunchie » Tue Jan 16, 2007 11:23 am
i ran 215 55's on my my ae101 and it rubbed under heavy cornering although my car was pretty low :P
"The air is heavy with antisipation as cozmo revs, drops the clutch and...... stalls with the hand brake on"........ "cozmo's hand brake one, cozmo 0"
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1201 <----Click to see real POWER :P
Lunchie
Postby AceSniper » Tue Jan 16, 2007 3:23 pm
at full lock you might touch the plastic undertrays of the engine
AceSniper
Postby 20v_rollaboy » Tue Jan 16, 2007 5:29 pm
They should fit. I have 215`s on my car and still have space between the shocks.
20v_rollaboy
Postby flygt4 » Tue Jan 16, 2007 5:49 pm
let me know if it fits, im loooking at using 225's for drag and maybe circuit. better you be the ginea pig :wink:
flygt4
Postby bluemaumau » Tue Jan 16, 2007 6:28 pm
yea lol.
i was looking at my inner guard earlier, which has bolt/screws heads which look like they may rub.
can you even roll front guards
Postby flygt4 » Tue Jan 16, 2007 7:22 pm
pffft inner guards are for noobs :D
altho i spent ages peeling rubber from behind the wheel in the engine bay area :oops:
flygt4
