4age bluetop ignitor plugs
Postby l1ttle_d3vil » Tue Jan 16, 2007 8:35 pm
got a 4age bluetop ignitor/coil here, its got the 3 green plugs; just need one of them confirmed.
2 pin plug - both wires are for the IGf and IGt ecu signals
1 pin plug - female; black/yellow. this is the 12v ign power for the coil + TVIS
1 pin plug - male; green/white. 12v batt, or earth? edit - loom may have been cut, so it might actually be a solid black wire originally
can someone confirm this for me??
cheers.
Postby l1ttle_d3vil » Wed Jan 17, 2007 4:20 pm
just checked out the wiring a bit closer and the green male plug goes straight to the + terminal of the coil. should this be a 12v + ign?
are there two 12v ign wires on these - one for the coil and one for the ignitor?
