pc wrote:I am running a lightened crank pully and have been for a few months, couldn't tell you what damage it might do long term, but i've not had any problems so far. I didn't get any balancing work done either.
I have a 0.5mm TRD head gasket and have planned about 1.1mm off the head. This is now 11.5:1 and runs fine on all factory stuff with 98 octane, done around 10,000km on this engine so far.
PS. I have new bearings, rings, stem seals, and ARP rod bolts tho.
so your still using factory ecu, injectors, fpr, fuel pump, etc etc??
im going to be using new rings, bearings, reco'd head with match porting and a mild cam grind with new valve springs. and listening to what you've said i'll get the same amount planned of the head.
also i may consider ARP rod and head bolts.
i wouldnt even considering running any less the 98 octane
thanks so far guys for the advice, many more q's to come from me in the not so distant future...
