Removing VVT from 20v. Advantage or Disadvantage?
Postby 20v_rollaboy » Wed Jan 17, 2007 11:06 pm
Also what would be involved in this? New cams or just new intake cam and wheel?
Would getting aftermarket cams give it more rpm but sacrifice low end power?
Would standard ECU be able to handle this? Or go Link?
20v_rollaboy
Postby big_boy » Wed Jan 17, 2007 11:12 pm
if you want to sell your pully let me know very intersted if it will fit my 5M witch it apperently will
big_boy
Re: Removing VVT from 20v. Advantage or Disadvantage?
Postby matt dunn » Wed Jan 17, 2007 11:17 pm
To disable it you can just unplug the VVT solenoid, but why?
Either,
My 1st race motor has aftermarket cam and just does not power the solenoid.
It still uses the std wheel but if you power the solenoid it just dont make any power.
The second Race engine I have uses a standard cam and does need the VVt working to get a decent amount of power out of it.
Depends entirely on the camshaft used. They are ground to specific specifications and that's what determines if you need the VVT or not and also if you need an adjustable cam wheel or not.
Thats the point of VVT so you can have both.
Once again depends on the cam,
if you go too wild the ECU will not like it.
Matt
Postby 20v_rollaboy » Wed Jan 17, 2007 11:29 pm
Thanks for that reply Matt. Are these race engines of yours still n/a or the turboed one in yuor DX?
I am probably going to go aftermarket ecu to remove AFM and it would probably help a bit overall aswell. Then get some cold air up there and free flowing exhaust system.
So would aftermarket cams be the next best thing or porting the head and leave cams as they are?
20v_rollaboy
Postby matt dunn » Wed Jan 17, 2007 11:34 pm
20v_rollaboy wrote:Thanks for that reply Matt. Are these race engines of yours still n/a or the turboed one in yuor DX?
My ones are all turbo application.
Really you need to match your cams to your porting work,
so best to do both at once,
but otherwise, um, dunno.
Not too sure how much gains you can get from either,
but If I was doing it i'd do cams first.
Postby 20v_rollaboy » Wed Jan 17, 2007 11:45 pm
Hmm thanks for that. Am contemplating to either keep it n/a and get some moderate power out of it or go the f/i way as so many people these days are.
20v_rollaboy
Postby spencer » Thu Jan 18, 2007 7:06 am
big_boy wrote:if you want to sell your pully let me know very intersted if it will fit my 5M witch it apperently will
Are you saying you want to try the vvt pulley on your 5m? :lol:
ms63 crown
spencer
Postby big_boy » Thu Jan 18, 2007 10:00 am
yep that means i can run 4600rpm power band peak on my cams & have a 2300rpm peak as well of the intake & also a 2200rpm & a 3900rpm peak on exuast witch should work out great
already have the cams :D
big_boy
Postby sergei » Thu Jan 18, 2007 10:45 am
Do you realise that you cannot have VVT pulley on non VVT car without extensive modification of the head (drilling holes, plugging holes, installing VVT solenoid etc..), also the VVT pulley has got bigger seal then non VVT. Also I doubt that 5MGE will have same size pulleys as 20v....
Postby big_boy » Thu Jan 18, 2007 10:54 am
apperently there the same size & tooth #
& apperently theres not alot involved to fit to my head iv got a guy all lined up to do it for me
big_boy
Postby sergei » Thu Jan 18, 2007 1:54 pm
big_boy wrote:apperently there the same size & tooth #
How is it going to activate?
Postby big_boy » Thu Jan 18, 2007 2:05 pm
from a jay car rev kit
big_boy
Postby spencer » Thu Jan 18, 2007 3:45 pm
This is great dual VVTing a 5m dont know why I havnt done this mod to my old 5m yet :roll:
ms63 crown
spencer
Postby big_boy » Thu Jan 18, 2007 3:55 pm
my only hope is that i can fit both the exuast & intake ones on
big_boy
Postby AceSniper » Thu Jan 18, 2007 5:45 pm
:lol:
AceSniper
Postby frost » Thu Jan 18, 2007 10:12 pm
you do know that the 20v only has intake side VVT. AND sergei is right it will need lots of drilling of the head to work because VVT is oil pressure activated not just switch it on buy solenoid. if you know this already then forget my crazy person rant and good luck.
Postby Loudtoy » Fri Jan 19, 2007 7:00 pm
I've got a spare pair of 20 valve cams (intake and exhaust) complete with pullys. How much are oyu keen to pay for them?? Pm me and let me know
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby matt dunn » Fri Jan 19, 2007 9:29 pm
big_boy wrote:from a jay car rev kit
Interested to know how you are going to get the oil pressure supply throung the centre of the cam while it is rotating and how you plan to drill the new oil feed galleries thru the head without hitting a water gallery?
Postby big_boy » Fri Jan 19, 2007 9:40 pm
its accually really simple my cams have a hole up the centre of them all ready not a big hole but bigger nuf for what i want they also have a revoveable end plate witch i intend on rinning the thro & in to the cams thro a seal ect then i entend on tapping the main oil gallerey to do this & also useing eletric solinoids powered by the jay car kit i entend on switching them its not as hard as people think on my motor
also Loudtoy i would only be intersted in the VVT-i cam pully/s if you are intersted to split can you please provide me some pics of it & sizes like teeth size OD ID key size
for sale EE90
big_boy
