Brake booster pipe -> inlet manifold 4age
Postby no_8wire » Mon Jan 22, 2007 7:16 am
Is the pipe that connects onto the intake runner (furthest from throttle)
from the brake booster?
Does this pipe discharge into the manifold or take air from it?
(reason being I want to remove the connection to the manifold as its fouling the fuel rail and was just going to put a breather on the pipe...)
no_8wire
Postby RomanV » Mon Jan 22, 2007 7:19 am
The brake booster uses vaccum.
So you definitely need it attached to have your brakes working properly.
Postby no_8wire » Mon Jan 22, 2007 7:38 am
But I will be running turbo so positive pressure...will this muck things up?
Or better to have it with a breather filter on it so it can draw its own air etc
no_8wire
Postby sergei » Mon Jan 22, 2007 9:19 am
You need vacuum there. If you disconnected and/or vent to air you will have rock hard brake pedal. It has got a check valve inline so boost pressure will not affect it.
Postby big_boy » Mon Jan 22, 2007 10:56 am
it only draws vacume under decerlation so the turbo will be running down any way causeing you to have vacume
also if you vent to air it will run real lean & draw air under idle & when you boost it will let pressure out so will run ritch
if you do decide to ditch it just plug it but rembour you stoping distance will just about double unless you get a right leg about 3 times as big to get the same stoping distance
for sale EE90
big_boy
