i might just humour toyota and use their chosen settings seeing as i have a torque wrench lying around.
either that or ill put a bit of loctite on the threads and do it up just tight enuf
IH8TEC wrote:i did mine up to 80ft lbs, which is 108nm
CAMB01 wrote:IH8TEC wrote:i did mine up to 80ft lbs, which is 108nm
The problem with over tightening bolts like that, is that they stretch and are under alot of stress, and can break or lose clamping pressure.
