st205 wrc internals?
Postby Infinite » Mon Jan 29, 2007 9:53 am
Ok,
what will these safely hold? 400hp like a normal 3sgte or what?, Ive looked arround for details but cant realy find much :(.
Lots
Infinite
Postby Akane » Mon Jan 29, 2007 9:57 am
They're the same as a normal 3S-GTE.
Postby Infinite » Mon Jan 29, 2007 9:58 am
they r forged arnt they....
Lots
Infinite
Postby Dell'Orto » Mon Jan 29, 2007 10:29 am
Nope.
Postby Mr Revhead » Mon Jan 29, 2007 1:53 pm
i think youll find they are.
just like the sw20 3sgte
Postby Dell'Orto » Mon Jan 29, 2007 3:41 pm
Forged crank? The pistons sure arent
Postby Mr Revhead » Mon Jan 29, 2007 3:52 pm
yeah the crank
and iirc the pistons are.... will check the set we have at home tonight
certainly didnt look cast
Postby Prymal » Mon Jan 29, 2007 5:32 pm
Semi forged if i recall , like the 4agze pistons
Theres a specific term for them but i cant recall it atm
and they will hold around 350 - 400 HP , but the question is for how long , till either your rings go , or your headgasket goes pop
If your looking to push the stock engine , at least double check headstuds and head gasket , the crank and rods will see that figure fine.
Prymal
Postby fivebob » Mon Jan 29, 2007 5:35 pm
Mmm, Boost wrote:Forged crank? The pistons sure arent
Are you sureabout that.
Postby Dell'Orto » Mon Jan 29, 2007 5:43 pm
So 3SGTE pistons are semi solid forged? How come they break so easily then? :(
Postby strx7 » Mon Jan 29, 2007 6:54 pm
Mmm, Boost wrote:So 3SGTE pistons are semi solid forged? How come they break so easily then? :(
Bad state of tune
Postby flygt4 » Mon Jan 29, 2007 7:06 pm
dont spose they are the same or similar material as 4agze ones? 4agze pistons take some pretty serious abuse to break.
i ran mine at 20psi for a while after i replaced the turbo with a new one the exact same, turned out it flowed so much more not being damaged it made the a/f ratios dodgy as hell. thought it felt faster :oops: turned out it needed a shitload of fuel added into the tune on the dyno. seems to have survived tho
flygt4
Postby vvega » Mon Jan 29, 2007 7:14 pm
its only the real wrc motors though i belive...gt420 had some for sale for a while
the only ones ive seen from a wrc looked quite forged to me....be it the same process as the 4agze ones
v
vvega
Postby Mr Revhead » Mon Jan 29, 2007 7:25 pm
p/n is the same for gen 3 sw20 and JDM st205. will check the group A ones tomorow
Postby Infinite » Mon Jan 29, 2007 7:47 pm
v
What do u define as a real wrc motor?.....
my 3sgte st205 motor is from a st205 that was a homologation model and has factory antilag water sparyers and ct20b turbo. yamaha head
Lots
Infinite
Postby vvega » Mon Jan 29, 2007 7:48 pm
v
sounds good
vvega
Postby Infinite » Mon Jan 29, 2007 8:06 pm
v
sounds good
so u reckon the internals are gona take 600hp safely?
Lots
Infinite
Postby fivebob » Tue Jan 30, 2007 12:19 am
Infinite wrote:What do u define as a real wrc motor?.....
Those are about the only differences between that engine and any other Gen III 3S-GTE, and they don't even work :?
The CT20B is stock on all Gen III 3S-GTE's, the only slight difference is the export models got the steel turbine, even the Japanese WRC models got the ceramic one that every other JDM Gen III had.
There's nothing special about a Yamaha head on a Toyota, it's stock on all 3S and a lot of other engines. Yamaha are Toyota's design partner and have been developing heads for the for the last 30 Years or so.
Infinite wrote:so u reckon the internals are gona take 600hp safely?
For about 30 Seconds, until the ring lands give up and cry enough :evil:
Postby Mr Revhead » Wed Jan 31, 2007 9:05 am
just checked, part numbers for export st205s are the same as JDM
Postby vvega » Wed Jan 31, 2007 4:34 pm
Mr Revhead wrote:just checked, part numbers for export st205s are the same as JDM
someone should tell gary and that guy that bout the 205 forged pistons off him
edit
he sold teh acl ones........ that he damaged
v
vvega
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
