Boosted_162 wrote:Where abouts on the AFM is it? Ill check against my facelift ST185 one.
Crimson Tears wrote:The intake air temperature sensor is more for fuel fine trimming, I've seen plenty of them unplugged and they don't seem to give too many problems.
Toymota wrote:I finally found a Samco 70mm 45 deg silicone bend at KiwiRE but its $117!! I know Toyota original parts are real expensive but do you guys reckon that an original rubber hose will be more expensive than that?
postfach wrote:Toymota wrote:I finally found a Samco 70mm 45 deg silicone bend at KiwiRE but its $117!! I know Toyota original parts are real expensive but do you guys reckon that an original rubber hose will be more expensive than that?
http://www.trademe.co.nz/Trade-Me-Motor ... 508438.htm
I use that stuff for my IC piping and it works fine, don't need to spend $120 on name brand stuff when you can get the same stuff for $50
