HELP with coilovers!!!
Postby muppet » Tue Jan 30, 2007 4:26 am
I'm looking at installing my rear coilovers to my St202 Celica and I can seem to see how the fit and work.
Does any one have any pics of some coilovers fitted to there cars as I might be able to work it from the pics.
muppet
Postby Adydas » Tue Jan 30, 2007 3:45 pm
They go in just the same as how your stock shocks would come out, dont they?
Unbolt the 3 bolts at the top drop it down after undoing the conection between the shock and
around where the brakes are i forget where its actually joined to, but it has 2 huge ass bolts holding it there.
and your out, reverse to put in.
Adydas
Postby gordon77 » Tue Jan 30, 2007 4:49 pm
yeah man its piss easy - if your break lines go through a plate mounted on the shock just pull the clip off and cut a slot so you can bend the pieces down and get the break line out - then u dont have to bleed ur breaks 8)
just be carefull not to cut ur break lines :twisted:
What is RR?
gordon77
