my new injectors
my new injectors
Postby NOLAW » Wed Jan 31, 2007 11:16 am
bought some s4 550cc injectors the other day and i noticed on of the caps around the spray bit has broken away on one of them, will this still be sweet to use? is it possible to get new caps for the spray? also does anyone know if these will fit into my 4agze fuel rail? cheers
NOLAW
Postby slonlo » Wed Jan 31, 2007 11:54 am
spray pattern will be screwed with it like that- not good to use like that
not sure if you can get new ones though
'89 LiteACE van
slonlo
Postby NOLAW » Wed Jan 31, 2007 12:39 pm
its algood, just went to a local guy and he gave me a replacement cap so iv got that sorted, now i just need to know wether they will fit into my GZE fuel rail/into the motor, anyone used these before in there ZE?
NOLAW
Postby IH8TEC » Wed Jan 31, 2007 12:45 pm
you'll find not many have used them, my sister still hasn't sent mine up to me :evil: but yes they will fit in the rail.
Postby Crucible » Wed Jan 31, 2007 1:14 pm
I just bought some rx-7 550's myself, Im working on my poo-banger this weekend getting a few things done and will be checking the injectors for size aswell, apparentley they go straight in. JasonT reckons the inj - head seals are the only thing that is differant and to use Mazda ones
I will post up my findings this weekend.
btw - what you pay for yours??
Crucible
Real Life Mechanic
Postby Jason T » Wed Jan 31, 2007 2:28 pm
Company called CDL in manukau city sells the pintle caps replace all of them
http://www.yellowpages.co.nz/Pages/Map/0,2876,a6001_c860_d5824931_l0_m0,00.html?businessName=CDL+Autoparts+Ltd&category=Fuel+Injection&mapKeyword=&location=New+Zealand#top
RX7 550's are a bolt in replacment for 7MGT 440's just need to get correct sized head seals RX7 are about .5mm bigger centre hole than toyota
Fixing Toyota's since '87
Jason T
