chassis rigidy vs cornering ability on uneven road
Postby Psycho_Dad » Wed Jan 31, 2007 10:15 pm
ok heres the idea
on an uneven road surface(ie most of nz roads) is it best to have a chassis that isnt completely rigid in order to get the best cornering out of the vehicle?? my theory is that since the chassis flexes, it would assist each corner of your suspension in working 'independantly' on oppose to a rigid chassis which would be like having a solid rear axil
im applying this specifically to cars that have independant suspension on all 4 corners, but am curious to how it would effect other options
any thought through thoughts would be appreciated
Peace
Psycho_Dad
Psycho_Dad
Postby Mr Revhead » Wed Jan 31, 2007 10:17 pm
a rigid chassis gives you a solid base to work from
with springs and shocks you can "tune" them
thats harder to do with a whole chassis
Postby matt dunn » Wed Jan 31, 2007 10:26 pm
Exactly.
most of the time you aim to get the chassis as solid as possible, so there is no flex at all.
That way you can adjust your suspension settings to suit the given conditions as you can control them.
Cant control or predict chassis flex.
Dad spent almost 6 months full time with ford in oz doing cages design's and testing with the BA's to eliminate chassis flex.
And do you realise how adjustable suspension is now days?
There's 4 way adjustable shocks, and that just IN the shock,
before you do camber, castor, toe, bump steer, spring rate, ride height,
sway bar stiffness, roll centre etc etc.
The less flex in the chassis the more accurate you can be with your suspension settings.
Matt
