4age 16v camshaft removal
Postby levinguy » Wed Feb 07, 2007 5:22 pm
hi,
im pulling apart a 4age bigport at the moment, just to learn a bit more as i no nothing
at this point in time it has no cambelt on and i have taken the all the caps off
i am stuck as to how i should go about getting them out without the cambelt on, as i cannot get the cam gear bolts off.
how do i go about getting them off? preferably without taking the gears off
also i was told and i did take the caps off in a certain order loosening them as i went. what is the point off this? and what would happen if i did not do this? just out of interest
thanks
levinguy
Postby Lloyd » Wed Feb 07, 2007 5:50 pm
Point of taking them on and off like that is so its basically pushing the cam down as a whole rather than hard down at one end etc which would twist things and stuff. Worst explanation ever, but you get the idea.
Should just come out once the caps are off. Give it a bit of a lever with a screwdriver and see if it pops out
Postby Brick » Wed Feb 07, 2007 5:53 pm
you will have to take the camwheels off. Did you mark top dead center before he cambelt came off?
With the caps they need to be undone/done up evenly as they tend to go on a angle, few turns each side etc.
once the caps are all off and cam wheels off(so much easier when marked fo putting the back together!) the cam should come straight out. If may need a wedge though :wink:
hope that helps
Brick
I know Kung Fu
Postby big_boy » Wed Feb 07, 2007 6:04 pm
to get the cams off now you hold a screw driver thro 1 of the holes in the cam & wedge on 2 something then undo the bolt
for sale EE90
big_boy
Postby levinguy » Wed Feb 07, 2007 6:31 pm
did not mark TDC, thought there was a mark on the camwheel that you can line up with the side of the head? or am i wrong? cambelt was off/proberly snapped when i got the engine
have been told to put the cam wheel back on straight after in the right spot or to mark where it goes on the camshaft
and for using a screwdriver have tried just now, and no luck. where should i be jamming it? im proberly to scared to put to much weight on it when i am jamming it.
levinguy
Postby Brick » Wed Feb 07, 2007 6:47 pm
where you located?
Brick
I know Kung Fu
Postby crispy'86 » Wed Feb 07, 2007 7:29 pm
you may have to take the backing plate off the head so you can take the cams out easily. i bet that's why you can't take the cams out. Had this trouble with my ae92 , just take camwheels off (which you've done) then unbolt the backing plate, 7 bolts and they come out. Maybe a little stuck in the end cap as they usually have sealer in them which makes it a bit hard to take the cams out. If you lever the cams don't lever against the head as you'll foul the gasket mating surface but you'll need a rather large lever and don't lever against the cam lobe (shiny part of camshaft. ) you'll damage the surface of it
crispy'86
Postby fangsport » Wed Feb 07, 2007 7:40 pm
i thought the camshaft had a machined hex between 1-2 piston, so you can put a spanner onto that and undo the pulley bolt??
fangsport
Postby levinguy » Wed Feb 07, 2007 7:44 pm
i havn't taken the cam wheels off thats my problem,
theres nothing stopping the wheel and the whole cam from turning
i was told to use a screwdriver but where abouts is safe to use it?
sorry if im hard to understand, im doing my best! :D
levinguy
Postby Brick » Wed Feb 07, 2007 7:50 pm
once you got the cam wheels off, take the 10mm bolts out of the blac matal guard thing here
taht will makeit easier to get the cams out.
you might be lucky and get the cams straight out, other wise if your going tolever it out make sure its no where important :D
Brick
I know Kung Fu
Postby levinguy » Wed Feb 07, 2007 7:50 pm
got it :oops:
pretty simple once i realised
thanks for the help everyone!
levinguy
Postby CAMB01 » Wed Feb 07, 2007 7:53 pm
Theres a hex on the cam a bit down from the cam wheel.
Put a cresent or spanner on that amd hold the cam while trying to undo the cam bolt
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby 2LTR Rona » Wed Feb 07, 2007 9:00 pm
fangsport wrote:i thought the camshaft had a machined hex between 1-2 piston, so you can put a spanner onto that and undo the pulley bolt??
Between 2 & 3 on my bluetop......
2002 Altezza, 1974 KE25
2LTR Rona
Postby fangsport » Thu Feb 08, 2007 12:19 am
have only been inside one 4ag, so am happy to be corrected. Toyota were usually pretty good at designing gear that was easy to work on, hence the reason why it's reliable in a standard form.
fangsport
Postby Dragger_Dan » Thu Feb 08, 2007 12:43 pm
Another way to get the gears off is to get somebody to hold them with a big $&#$% off set of polygrips. In fact almost any automotive problem can be solved with big polygrips.
Dragger_Dan
Postby big_boy » Thu Feb 08, 2007 5:42 pm
& a big hammer can also fix any thing
if it dousent work hit it with a hammer if that dousent work get a bigger hammer :twisted: :twisted:
for sale EE90
big_boy
