k50 alternative filler - bolt rounded
Postby nic32 » Wed Feb 07, 2007 10:37 pm
Hey hey,
I've almost finished putting a 4age into an ae85 - however when I went to
top up the k50 gearbox that I'll be running for a while I found someone had previously rounded it off. Is there some other way to top up this box so that I can drive it to a mechanic to use an oxy plant(another bolt on the box or thru the shifter)? I've given the bolt a good going over but can't shift it - was thinking worst case could jack car up and feed it thru the end of the box.
nic
nic32
Postby Meadzy » Wed Feb 07, 2007 10:45 pm
on mine i just unbolted the shifter and poured it in there.its fine to do..or is that where youv rounded the bolt off?
"Keeping it true to the JDM"
J-Spec Group
http://jspecgroup.com/forums/index.php
AE86,200sx,EG6
Meadzy
Postby nic32 » Wed Feb 07, 2007 11:18 pm
Nah I rounded off the filler bolt on the side. Sweet will put it in there, any idea how much it takes?
chur chur
nic32
Postby Dell'Orto » Wed Feb 07, 2007 11:40 pm
The K series ones take just shy of 2.5l. Try using a chisel to get the bolt off, I've had to do that on an old K50.
