Hello..
I have recently just purchased a Sard ECU for my AE101 silvertop with is a straight plug and play for a manual..
when i removed the original ecu it had A/T stamped on it so the previous owner may have done a auto/manual conversion and used the auto ecu.
my problem is i have rewired the auto loom to match the M/T loom wiring diagram on here http://www.club4ag.com/faq%20and%20tech_pages/ECU%20Japan%204age%2020V%20Silver.htm
i picked up a 12pin ecu plug to replace the 22pin dash plug and the other 26pin and 16pin fitted fine
i have rewired all the wires but still won't run
i have 4 wires that havn't been used
all from the 22 pin auto plug
pin 22
pin 07
pin 14
pin 15
could this be the reason it isn't running?
