Brakes, upgrade options?
Postby bbq1988 » Wed Feb 14, 2007 12:34 pm
Hey guys, what brakes would you reccomend putting on a ST206 Curren for a bigger upgrade?
Also, who makes extractors for the 3s-ge? price?
Baked, Not Fried.
bbq1988
Postby KinLoud » Wed Feb 14, 2007 1:40 pm
Start with good brake pads and new fluid. These will fix any fade problem you might experience.
It takes an awful lot of continuous hard driving to need bigger brakes.
However... if you feel you really need/want bigger brakes you could track down some ST202/206 superstrut brakes and adapt them to your car (presuming it's not S/S already). My best guess is that you might have to reduce the disk diameter by 5 to 10mm and make a spacer to centre the superstrut twinpot calipers.
ALSO - try to get the brake bias valve off the superstrut donor and maybe the brake booster as well.
These mods might need to be certified!
Ken
Ham
021 408 863
Postby bbq1988 » Wed Feb 14, 2007 1:47 pm
ah cheers, yeah it already is the s/s model
Baked, Not Fried.
bbq1988
