4agze piston question
Postby rage » Fri Feb 16, 2007 9:20 am
This might already be answered, or general knowledge or whatever, but I DID do a search and couldnt find anything specific.
How much power can a standard 4agze piston handle? maybe examples of high power applications using the standard pistons?
Also is there any difference in the strength between the high comp and low comp pistons ?
rage
Postby IH8TEC » Fri Feb 16, 2007 10:31 am
guy in aussie has around 300kw atw in a rwd cortina, at 30psi, had 287kw atw on his old setup, wasn't the speedtech dx around that too?
all in the tuning as they say
Postby rage » Fri Feb 16, 2007 11:09 am
awesome. thanks for that.
so the low comp and high comp pistons are the same strength ?
rage
Postby IH8TEC » Fri Feb 16, 2007 1:03 pm
some say so, by the way the one i mentioned above was with 8.0:1 pistons
