4agze owners please
4agze owners please
Postby Mike- » Fri Feb 16, 2007 12:11 pm
i did a search but couldnt find anything specific so anyway, can i use the supercharger on the right to replace the one on the left?
the one on the left is from an ae101, and the right an ae92. are there any differences in the clutch or wiring that would cause it to not work?
thanks for any help
Mike-
Postby ~SlideWays~ » Fri Feb 16, 2007 12:32 pm
The clutch/pulley size is most likely going to be different, the ae101 sc will give you more boost. The very late MAP ae92's where just the same pulley/clutch btw.
You can just swap the clutch setup over if need be.
~SlideWays~
Postby Mike- » Fri Feb 16, 2007 1:52 pm
ok sweet, i bought the ae92 one because the 101 was making some rude noises, turns out it was that pulley. mite just put the ae92 one in then as the old one had no oil in it either
Mike-
