atmosports wrote:Manifold shouldn't be too difficult, but then I say that as I'm forever playing with manifolds to put this onto that & it's quite amazing how many other engines a st205 side draught manifold will actually fit ith a bit of cutting & filling.
You wo't necessarily need to fit the toyota tps, you'll just need a TPS that's the same style(either switch or variable resistor scaling type) & then you'll need to pick one which bolts onto your throttlebodies & rotates the right direction. The only last thing to worry about is output voltage & the plug/wirinbg it up, you'll more than likely find the nissan one would work with just a plug change especially if your running an aftermarket ecu of some kind.
