im building a 7agte for my kp60 and im just curious as to what would be a good injector to use also what cc?
will go expensive aftermarket a bit later however would there be any other descent interchangable ones that i can get off other cars?
Caveman wrote:IIRC 500cc/min will supply 100HP
My 4agze injectors were flowed at 430cc across all four. The guy that did the work (petroject in albany) said he got a similar result from the last 4agze ones he did,
matt dunn wrote:Caveman wrote:IIRC 500cc/min will supply 100HP
That's not a typical result then as I have done at least 3 sets of 4AGZE ones at work and they were all 365 +/- 10.
Caveman wrote:matt dunn wrote:Caveman wrote:IIRC 500cc/min will supply 100HP
I will look for the results sheet but I was suprised at the ratings. This is at full duty cycle at 3bar, not at 80% cycle as typically quoted.
Caveman wrote:not at 80% cycle as typically quoted.
