play in door hinge
play in door hinge
Postby slonlo » Fri Feb 16, 2007 4:53 pm
whats the best way to fix play in a door hinge
my lower drivers hinge has just failed a warrant
77 ta23 celica
cant you get rebuild kits?
or can engineering shops bush them?
'89 LiteACE van
slonlo
Postby spencer » Fri Feb 16, 2007 5:01 pm
check with revhead got some new ae86 ones ages ago. Might not be so lucky with the age of your car? worth a try
ms63 crown
spencer
Postby slonlo » Fri Feb 16, 2007 5:16 pm
yeah no longer in the system apparently - so no luck there
'89 LiteACE van
slonlo
Postby fangsport » Fri Feb 16, 2007 6:21 pm
i have had much success with re-bushing Navaras and Hilux's , as due to their type of use, the pins wear out very quickly, and the factory re-bush kits are very expensive
e-mail or PM a photo of the hinge, and i'll see if it can be re-done in the same fashion.
fangsport
Postby matt dunn » Fri Feb 16, 2007 6:59 pm
I've had an engineering shop make up new bushes for door hinges before.
Postby big_boy » Fri Feb 16, 2007 9:59 pm
if there the same as MA61 chuck us a PM i got 1 u can have
for sale EE90
big_boy
Postby Ae92typeX » Fri Feb 16, 2007 10:31 pm
a basic way to fix, which lasts.
Buy a coupple (or may just need one) drill bits, larger then current hinge pin. Drill through (dead straight), angle grind off cutting part of drill bit, put a washer top and bottom and a spot of weld to hold. clean up, paint, done. works fine.
otherwise, if length to long for drill bit, get some steel rod & drill bit correct size, use rod as above with cut and weld.
Ive done that several times over the years with no issues, looks fine and cheap as chips.
oh, and grease it also once painted.
Ae92typeX
Postby GT4RGED » Sat Feb 17, 2007 10:53 am
If you gimme your full chassis code I can try and get some new ones for you. Should only be about $40+GST each. According to my TNZ system they are coming up discontinued, but most of the time thats not the case.
Rory - 1991 ST185 Celica GT-Four Group A Widebody
Parts Consultant, King Toyota Lower Hutt
GT4RGED
