pyro_sniper2002 wrote:You have to loosen off the pully for the tentioner to move, not just ajust the tentioner bolt.
slighty_sykotic wrote:pyro_sniper2002 wrote:You have to loosen off the pully for the tentioner to move, not just ajust the tentioner bolt.
he knows that. Thats the botl he can't undo.
You might have to use a hacksaw blade.
And yup, it will take you hours
Been there.....
XSVWGN wrote:or what i have had to do in the past is drill the head of the bolt off and undo the tensioner pulley and then replace the bolt with a brand new one and i have not had any problems since then
Matt
AE82 FXGT wrote:...
I also can't fit a hacksaw in there to saw it off either.
ae93_sx wrote:I know the bolt you mean & have had the same issue. Good luck getting a hacksaw blade in that gap! In the end i took the whole bracket that holds the tensioner pulley off. This is a bitch of a job because you need to remove the aircon, alternator and PS pump to get the bracket off. Took maybe an hour or so.
Once i had it off i could easily loosen the bolt. Once back on, i tightened it best i could with one of those angles spanners. Been going fine for ages now.
