mine is ae92!
when i purchased the gtz and removed the engine these two lines (back of throttle inlet) were plugged up like so: is this correct?
im completely $$% when it comes to ze lines.
any help is appreciated
soopachargen wrote: have you tried the twincam.info forum?? that has some good info
bluemaumau wrote:o and i just need to plug up the line on the blue vsv correct?
escortman wrote:which line would that b, cuz atm i have nothing running to my abv
well get some line and run it to your intake and a t piece, then also run a line to the brown vsvescortman wrote:which line would that b, cuz atm i have nothing running to my abv
bluemaumau wrote:i cant just take the abv straight to the intake tho as it needs to also hit the brown vsv. so i should just tee it?
then plug up the vaccum on the intake and remove the blue vsv?
bluemaumau wrote:looking at the diagram you posted,
your saying "t" the abv and boost guage line at line "e"
i would have thought line "B" would have been correct, thats were my boost guage is currently
