Gutting or removing Cat Converter?
Postby TOYO-GT-T » Mon Feb 19, 2007 7:37 pm
Just wondering what the pros and cons are?
You would think gutting the cat would be the best option if it has similar results to removing it due to the exhaust laws getting tighter?
If you still have the cat in place (gutted) hopefuly this will good enough to pass your W.O.F regarding your exhaust so long as it's not to loud.
I know at this stage you do not require a cat. I don't know how much longer this law will be around for.......
I am not trying to produce massive HP just putting in place a cat back exhaust system to help the car move along a little better.
TOYO-GT-T
Postby evil_si » Mon Feb 19, 2007 9:34 pm
when it is introduced wof testing will be done by emission tests, not just the fact there is one there
if you want it gone just cut it out, much easier than trying to gut it
evil_si
Postby RomanV » Mon Feb 19, 2007 10:27 pm
Gutting the cat is a crappy idea, get it cut out and replaced with a resonator, or straight piece of pipe.
Postby Ae92typeX » Mon Feb 19, 2007 10:53 pm
Ae92typeX
