4AGE Cam Specs
4AGE Cam Specs
Postby z0ton » Wed Feb 21, 2007 6:57 pm
I'm in the middle of putting some bluetop cams and adjustable cam gears on my 4agze and the engine reconditioner wants the cam specs with centre line or something? I don't know exactly what he needs... Does any know and have this info?
z0ton
Postby Crucible » Thu Feb 22, 2007 7:19 pm
The in cam dowel is at 12 oclock and the exhaust cam dowel about 5oclock. Same as gze cams.
Probably best to position them with the gze pulleys & marks, make your own marks then fit the adjustys and go from there.
if you get lost you can go back to the seperate marks you have made. Wouldnt think you would get much differance with moving bluetops from stock marks? if anything it would be flat like getting the valve timing out a tooth...
Crucible
Real Life Mechanic
