smallport 4age ring size
Postby AE85coupe » Thu Feb 22, 2007 12:33 pm
hey guys i'm currently rebuilding my engine and when i went to buy rings for the job i was given two sizes
what size are smallport rings meant to be?
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby AE85coupe » Fri Feb 23, 2007 12:09 pm
bumpity bump
come on, i know someone has rebuilt these before and must know?
Details of car here
AE85coupe
Postby no_8wire » Fri Feb 23, 2007 12:19 pm
Was it thickness or diameter that was different?
no_8wire
Postby AE85coupe » Fri Feb 23, 2007 12:34 pm
thickness
Details of car here
AE85coupe
Postby Brick » Fri Feb 23, 2007 12:58 pm
i just threw my invoice out yesterday for the rings i got for my smallport,
sizing was 1.2, 1.5 but i cant remember the third maybe 2.8?
did you take a piston in with you when you went in?
Brick
I know Kung Fu
Postby Bling » Fri Feb 23, 2007 1:51 pm
tried toyota? they should know
Postby Dell'Orto » Fri Feb 23, 2007 5:15 pm
I think there are a couple of options, depending on the year. Or it may have just been for big vs smallport redtop.
Postby CAMB01 » Fri Feb 23, 2007 7:36 pm
Measure the ring grooves on the pistons.
Should be 1.2mm, 1.5mm, 2.8mm.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby crispy'86 » Sat Feb 24, 2007 12:01 am
smallport is 1.2mm top ring, 1.5mm and the oil clearance ring with the two shims, thats where the 2.8mm comes in
crispy'86
