Alignment of Pulleys
Postby z0ton » Sun Feb 25, 2007 1:49 pm
I'm just in the process of putting together my 4agze and I notice when I spin my air con pump the pulley sways from side to side a bit. Its just gunna be used as an idler but will this rip belts to pieces or affect how they run? What actually causes it? I got a new bearing put in it but it did get pressed in properly...
Also when the engine got rebuilt someone took that pipe off that the oil runs from the head down to the block through. I understand its pressed in somehow but how do I do it?
I found a pic of one...
http://uploadimages.com/view.php?type=t ... 956421.jpg
z0ton
Postby bluemaumau » Sun Feb 25, 2007 1:52 pm
is the aircon still held by the 4 bolts??
Postby z0ton » Sun Feb 25, 2007 1:55 pm
bluemaumau wrote:is the aircon still held by the 4 bolts??
Yea of course its all how it normally is but just nothing is hooked up to it.
z0ton
Postby bluemaumau » Sun Feb 25, 2007 1:57 pm
wtf, there obviously tight? pulleys tight?
$&#$% it just get a new one
Postby z0ton » Sun Feb 25, 2007 1:59 pm
bluemaumau wrote:wtf, there obviously tight? pulleys tight?
Yea its just the pulleys. You know when you spin them fast and they move side to side slightly. I just wanna know how much movement they can have before they will start eating belts...
z0ton
Postby bluemaumau » Sun Feb 25, 2007 2:01 pm
i cant say mine moves much, maybe +/- 1mm
