Celica GT4 wheel offset.
Postby RedMist » Mon Feb 26, 2007 11:05 pm
Looking at some 15 inch rally rims. There are some Subaru 45mm offset rims on Trademe at the moment. Has anyone run 45mm offset rims on a Celica before?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Norty » Tue Feb 27, 2007 7:37 am
need adapter plates so i have been told.
Norty
Postby Adydas » Tue Feb 27, 2007 7:54 am
i belive the 185s offset is +35 if that helps, but the only way around fitting to guards on my car is going to be with rear spacers.
Adydas
Postby TRD Man » Tue Feb 27, 2007 12:55 pm
Redmist, I have 2 sets of 15 x 7 OZ racing rims and 1 set of 16 x 8 OZ 5 spokes - all off Celica.
The 15" have 1 set of 205/55-15 Toyo seal tyres and 1 set of 205/50-15 Bridgestone seal tyres in good nick.
Any interest?
TRD Man
Postby Prymal » Tue Feb 27, 2007 1:16 pm
oz racing rims for the win
they are usually + 35 - which for a 20-5 is pretty much perfect ..
Spacers + rallycar = a bad thing , seeing those are going to see off ground excursions
Some early STI rims will fit Gt4's but the main issue is clearing the big brakes ..
Im not sure if this will apply to you after the brakes change to meet rally rules though
16 X 8's on that offset *may* foul the rear struts on a gt4 - i know they fouled onmy Old St185 rim cleared by a millimeter or two - tyre would have rubbed - the only way to fix that is indeed spacing
17 X 8 doesnt have this problem
& inch wide shuld clear with no dramas , this is what i ended up on my 185 with no clearance issues ( 17 X 7 racing harts )
Prymal
