anyone knows what is the best way to read A/F ratio??
Postby 13 » Tue Feb 27, 2007 11:16 pm
as the title says...just going to tune my 20v with safc so need a a/f ratio reading ....anyone knows what is the best way to do this???thanks
13
Postby RomanV » Wed Feb 28, 2007 12:04 am
Either go to a dyno, or make friends with someone that has a wideband oxy sensor.
Buying a wideband would be more expensive than going to the dyno, and a narrow band 02 sensor doesnt really tell you much of anything useful.
Postby Akane » Wed Feb 28, 2007 12:14 am
Well, correction to that, the narrow band will tell you which side of stoich you're at... haha
Postby strx7 » Wed Feb 28, 2007 7:14 am
find someone 'locally' with a portable wideband set up.
Postby 13 » Wed Feb 28, 2007 12:35 pm
ok thanks guys....any idea where to get a wideband set up???
13
Postby postfach » Wed Feb 28, 2007 12:47 pm
postfach
Postby Crampy » Wed Feb 28, 2007 1:31 pm
13 wrote:ok thanks guys....any idea where to get a wideband set up???
I've seen a few set ups on Tardme. There was one that has an EGT sensor as well.
Crampy
Postby strx7 » Wed Feb 28, 2007 1:44 pm
