custom gearbox rubber mount?
Postby Burning Angel » Thu Mar 01, 2007 5:38 pm
Is there an easy(or cheap really) way of making a rubber mount/insulator for a gearbox. The gearbox in question is a nissan 5spd bolted to an sr20.
basicaly just need something to go between the gearbox and crossmember.
I dont really want to pay 150~200 bucks for a new one.
i have seen a soloution like this:
using a urethane block but is this legal with standard rubber engine mounts?
any help would be much appreciated
Burning Angel
Postby 2LTR Rona » Thu Mar 01, 2007 6:31 pm
you could have a chat to the man who started this thread...
viewtopic.php?t=55080
May or may not prove helpful
2002 Altezza, 1974 KE25
2LTR Rona
Postby Ae92typeX » Fri Mar 02, 2007 5:15 am
had a scrounge around a local werckers to see what there is available to adapt? I would probably tke thet route if the exact mount was not available.
depending on the car use, ive used a more solid urethane type mount on a rwd box before. Was a daily road driver, and the hard mound caused too much noise/vibration transfer I replaced it a day later.(a softer grade may have been fine)
Ae92typeX
Postby Burning Angel » Fri Mar 02, 2007 9:25 am
yea noise isn't really an issue as the car is a rally car(that ill probably drive everyday anyway) but i dont want it too solid incase it ends up breaking stuff.
Burning Angel
