3sge fuel pressure regs ?
Postby phrogmodz » Fri Mar 02, 2007 9:30 pm
got a mr2 3sge motor and im having clearance problems
with the fuel pres reg
it pokes straight up out of the top of the rail at the cam cover end
anyone aware of any other options on location between the different models?
cheers- phill
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby groupagt4 » Fri Mar 02, 2007 11:47 pm
is this a aftermarket one or just the factory regulator
groupagt4
Postby phrogmodz » Sat Mar 03, 2007 12:49 pm
factory fitted
think i might b able to swap ends on the rail
to make it work though
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
