ST215 - Oil cooler
ST215 - Oil cooler
Postby AJz » Sun Mar 04, 2007 10:08 am
Has anyone successfully changed the stock watercooled oilcooler in a ST215 to air ???
I think that main problem is gonna be to get it all to fit. And then a case of blocking off the water pipes but that aint hard.
Its just an idea, curious to see if others have done it......AL (DrivenPerformance)???
I had vtax :(
AJz
Postby fivebob » Sun Mar 04, 2007 10:11 am
Why remove the stock cooler?
Just do what all the aftermarket kits do, use a sandwich plate on the oil filter.
Postby AJz » Sun Mar 04, 2007 10:57 am
makes sense, did you do this on yours ???
I had vtax :(
AJz
Postby fivebob » Sun Mar 04, 2007 11:26 am
Not yet, mines already got the sandwich plate, but it's taken up with oil temp & pressure sensors right now.
