how to stick insulating film to IC (3sgte)
Postby dougsop » Mon Mar 05, 2007 4:56 pm
what sort of glue, tape or spray should i use to stick the insulating film to the IC ?
does it need to be heat resistance?
what is it called and where do i get it ?
thank you
97 Toyota GT4 ST205 1st run 16.2psi 181.2KW
more to come...
dougsop
Postby Prymal » Wed Mar 07, 2007 11:10 pm
i believe the lagging you mean has an adhesive backing o it
you can get it from most reputable speed shops ( read not repco , or supercheap auto , for the most part )
make sure the core is spotlessly clean, then you should be ok ..
somewhere like the GT4OC ( uk based gt4 dedicatyed forum ) might have a HOW TO on doing this
A few mates in oz have also done it on their 205's with better than stock results
Prymal
Postby BR0Z » Thu Mar 08, 2007 12:24 pm
I bought some insulated stuff off Adrian at Jap Race & after stripping all the paint off my WTA I/Cooler proceeded to stick it to the underside with 'No more nails' + running I/C pump constant keeps I/C much cooler.
The stuff I got is shiny on one side & weaved heat material stuff on other.
The 'No more nails' worked a treat & I've had no problems.
Instructions were obtained from GT4OC which I have saved as a Word doc so if wanted I can send to your e-mail.
Let me know.
Cheers, Mark
Oldie but goodie
Mark Bros
91 GT FOUR RC x 3 1 Red (mine) Daniel - 2 White - 1 damaged & for sale =(
May the FOURce be with you
http://toyspeed.blakjak.net/profiles/profile.php?id=244
BR0Z
Users browsing this forum: Bing [Bot] and 8 guests
