Mmm, Boost wrote:Just unplug the hose from the boost pressure sensor and block it off, that disables it. Don't bother going higher than 15psi on the CT26
Mmm, Boost wrote:Yup.
Edit: Ah, found graph - was 20hp, not KW. After thinking about it I thought that sounded a bit high.
solitaire wrote:Mmm, Boost wrote:Yup.
Where you on a ct26 mate?
Ive heard stories about compressor wheels shattering above 12psi
