ke70 dash lights coming on with brake pedal??
Postby l1ttle_d3vil » Sat Mar 10, 2007 8:35 pm
got a wee problem with the ke70 - all the lights work sweet as normal, apart from the fact all the dash lights will come on when i push the brake pedal.
My guess is a couple of wires are melted together, or someone has joined the wrong two wires.
Where's the best place to start checking?? anyone who knows a bit about the ke70 wiring have any pointers, maybe save me a bit of time and frustration?!
its a 1984 ke70 wagon if it matters. i know its a long shot but worth a try :lol:
thanks.
Postby big_boy » Sat Mar 10, 2007 8:53 pm
take out all your rear bulbs & tell us what happens
im gessing one break light is missing an earth so is earting thro the dash light system after crossing over at the back lights
for sale EE90
big_boy
Postby l1ttle_d3vil » Sat Mar 10, 2007 9:43 pm
ah you legend :lol: took the back left brake bulb out and it works sweet.
why would that be missing an earth? is it the white/black wire which should be the earth? any idea where the other end of that wire is? :roll:
Postby Zak » Sat Mar 10, 2007 9:45 pm
it's the filimant shorting against the second one in a twin filimant bulb.
Zak
Postby big_boy » Sat Mar 10, 2007 9:48 pm
never heard of that ZAC but maby
normaly is poor contact or a broken wire
for sale EE90
big_boy
Postby matt dunn » Sat Mar 10, 2007 9:49 pm
Make sure the bulb has two contacts on the bottom the same as the rest,
sometimes people it a single contact bulb which joins the two together,
or sometimes it is just a faulty bulb.
It's a common problem we see at work with all cars.
Postby l1ttle_d3vil » Sat Mar 10, 2007 9:57 pm
matt dunn wrote:Make sure the bulb has two contacts on the bottom the same as the rest,
thats it - checked the wire and it was earthed but the bult is a single contact. swapped it with the twin contact bulb from the drivers side and its sweet.
interesting something so simple can cause such major problems - I was thinking something alot worse :?
can this sort of thing cause indicators to flash quickly too? all 4 are doing it, but not the hazards. unless its just a coincedence that all 4 are going to blow soon :D
Postby big_boy » Sat Mar 10, 2007 10:02 pm
a weak flasher will do that
for sale EE90
big_boy
Postby l1ttle_d3vil » Sat Mar 10, 2007 10:18 pm
weird thing is now its only the right side flashing fast - they've all been doing it for ages now it all of a sudden changed.
thought it may be to do with the brake lights so I put all the bulbs back in exactly how they were before hand and the left one was still normal speed.
the only way I can get the passenger side to flash fast again is by removing the indicator bulb.
ive tried swapping the bulbs around (passengers/drivers side) but it doesnt change anything.
this sound more like earths or bulbs? or still a faulty flasher?
Postby big_boy » Sat Mar 10, 2007 10:20 pm
bulbs being different/rong wattages or mabyt earth not so likley if there all going
for sale EE90
big_boy
Postby l1ttle_d3vil » Sat Mar 10, 2007 10:49 pm
bulbs are the correct wattages and are the same as each other too.
where would be a good place to start looking for a dodgy earth, just follow the wire back from the indicator? or something in the fusebox/dash area?
if it was a faulty bulb, would unplugging / removing that bulb fix it?
Postby big_boy » Sun Mar 11, 2007 9:03 am
go round each earht with a muilty meter & go from each bulb to chassie something good & clean like a boot catch ect set the muilty meter to volts & check V.D
also if it was a faulty bulb take each one out & swap with a good one from the other side & see what happens
for sale EE90
big_boy
Postby l1ttle_d3vil » Sun Mar 11, 2007 11:11 am
big_boy wrote:check V.D
whats that? :oops:
its nothing to do with the bulbs, i've swapped them every way possible and doesnt change a thing.
Postby AE82 FXGT » Sun Mar 11, 2007 11:49 am
whats that? :oops:
Voltage Difference?
AE82 FXGT
Postby big_boy » Sun Mar 11, 2007 8:27 pm
voltage drop :)
for sale EE90
big_boy
Postby l1ttle_d3vil » Sun Mar 11, 2007 9:51 pm
big_boy wrote:go round each earht with a muilty meter & go from each bulb to chassie something good & clean like a boot catch ect set the muilty meter to volts & check V.D
ah thought so...are you talking about removing the bulb and checking the voltage at the bulb contact point? sorry, just a bit confused...not totally clued up with this part of it.
any chance you could explain a bit better?? :oops: thanks!!
Postby big_boy » Sun Mar 11, 2007 10:15 pm
um if you put your muilty meter on 1-20v dc & put 1 lead on the earth point of the bulb holder & the other on a good chassie earth & see what they read it sholud be between .001-.5V the less the better
for sale EE90
big_boy
Postby thaphatty » Mon Mar 12, 2007 9:09 am
big_boy wrote:& check V.D
Venereal disease. always check for those.
thaphatty
