1990 Toyota hilux surf injectors?
Postby Roydon » Mon Mar 12, 2007 4:56 pm
Howzit guys, How much time and money would it take to change injectors on one of these engines. Is it a big job or a simple half day max type of thing and am i guna go broke trying to find the parts for it? Also does anything else need to be changed at the same time?
"Its hard enough trying to remember my opinions without trying to remember my reasons for them"
Roydon
Postby ee904age » Mon Mar 12, 2007 5:27 pm
Petrol or diesel???
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby big_boy » Tue Mar 13, 2007 10:40 am
diesel its about 1-2hrs max
petrol from memory about an hour for the early ones or about 3-4hrs for the later
i think i have petrol arround the right way but i may not 1 you have to tkae the hole intake off 1 you dont
for sale EE90
big_boy
Postby Roydon » Tue Mar 13, 2007 5:03 pm
oh yeah sorry its 2.4l diesel turbo.
Roydon
Roydon
Postby sergei » Tue Mar 13, 2007 5:19 pm
With diesels it is not just a straight swap, you have to "adjust" them aswell, which you can only do with experience and special equipment.
Well, that is atleast how I understand.
Postby Phothog » Tue Mar 13, 2007 8:51 pm
Diesel injectors are relativly easy, just unbolt the pipes, & return rail making sure you dont snap any of the lines, unbolt the injectors.
get you new/recondition set and put them in, dont forget to pull the washers out & use new ones. all three washers the little heat washer, the sealing washer. & the return washer.
bolt the injectors in place the return rail on with your new washers, tighten up the bolts holding thereturn rail on, reattach the injector pipes.
as for adjusting them, the adjustment is made when the injectors are cleaned up & nozzles are put in.
Chris.
Phothog
Postby Roydon » Wed Mar 14, 2007 3:17 pm
sounds simple enough, what about cost?
Roydon
Postby Phothog » Wed Mar 14, 2007 9:31 pm
Roydon wrote:sounds simple enough, what about cost?
For doing the job or the injectors ?
say it takes three hours @ $65 per hour (our retail charge price)
and for a set of exchange injectors about $220 - $350 +Gst
price depending the the injectors there is about 3 or 4 different ones for the 2lt engines.
Chris.
Phothog
Postby Roydon » Thu Mar 15, 2007 7:35 am
wicked thats great cheers every one
Roydon
