ok i've figured its got no spark, for some reason it had a small spark yesterday though. definitely nothing at all there tonight though.
unplugged the cold start, no change. i've tried two different dizzies, both with the timing setup accurately and still nothing. compression was 125 on #1 cylinder, didn't check the rest as theres no spark before it even gets to the compression point
I've checked all the connections between the dizzy / ecu, and the ignitor / ecu and they're all fine. also not the ecu which is faulty.
there is power at the coil / ignitor, so pretty sure it isn't any of that wiring come loose. all I can think is it would be the coil and / or ignitor which is faulty, I've tried a different one but it had different plugs so had to wire it up temporarily - may have got something wrong.
Is there any easy way to test my current coil and ignitor though? From memory don't auto electricians have a tester they can connect them up to, or is that just the coil??
-matt
