Toyota Vista VR - strange problem???
Postby Vista » Wed Mar 14, 2007 9:26 pm
:roll:
Started my car after work, being a desiel, I have to wait for the coil to heat giving a beeping sound to turn the key (all the oil, coil, water etc dash lights on), well it beeps ok, turn the key, motor starts ok( all lights should go off), the funny thing, he oil, boost lights etc stay on, plus the buzzer that tells you the keys in the ignation when you open the door sounds - doesn't go off till I'm 1/2 way home.
Get home check all the fuses, reset the ECU, by disconnecting the battery, still no joy.
Thanks everyone in advance,
Duke
Vista
Postby Silent Knight » Wed Mar 14, 2007 9:48 pm
Sounds like some sort of an electrical problem with the dash...
Silent Knight
Postby big_boy » Wed Mar 14, 2007 10:01 pm
im questioning an earth
or a warning device to say something is rong (a few cars do this for the likes of fans ect)
just a thort but
all these lights are normaly supplyed with power & use earth to trigger
the buzzer is normaly supplyed with power on both sides in its normal state
(+12v from the light switch & +12v from the on pission of the key) when the key is off how ever it shows ground same with the light switch how ever the buzzer wont buz if its showed ground on the light side hence this is how it works but if you were conecting the buzzer wire to the lights via a short the buzzer would go & so would the lights
so next time it douse it turn you lights to the opposit to what there at at the time & see what happens
yes its a long shot
for sale EE90
big_boy
Postby Vista » Fri Mar 16, 2007 8:23 pm
:lol:
Thanks for the replies - big_boy, Silent Knight.
Found the problem- it was warning for the alternator, being stuffed, $60 later (new brushes) ,alls well :D
Vista
Postby vvega » Sat Mar 17, 2007 8:02 am
Vista wrote::lol:
sounds liek a cheap fix :D
well done
vvega
Postby matt dunn » Sat Mar 17, 2007 9:01 pm
Yes a cheap alt fix by the sounds of it, but most of the pre 2000 diesil's can be done like that quite well.
And if you are wiating for it to beep before starting it you are waiting too long.
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
