Colder plugs for a high comp 4age
Postby ChaosAD » Thu Mar 15, 2007 7:53 pm
Ive bumped the compression on my bluetop up to 11:1 and am going to add some wild cams.
What are your guys reccomendations for plugs? I need to go at least one heat range colder, but at $80 a set I wana get it right.
and should I go iridium, platinum, or otherwise?
Thanks
ChaosAD
Postby EVLGTZ » Fri Mar 16, 2007 1:43 am
I just go with the heat range to suit but in copper plugs
heaps cheaper and just change em more often. new plugs are always good
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby pc » Fri Mar 16, 2007 9:04 am
I'm just using standard cheap plugs in mine and it's 11.5:1. Haven't changed them in over 7000KM and it still runs fine.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby aesc » Fri Mar 16, 2007 9:23 am
Taken from the NGK website
With modified engines (those engines that have increased their compression) more heat is a by-product of the added power that normally comes with increased compression. In short, select one heat range colder for every 75-100 hp you add, or when you significantly raise compression. Also remember to retard the timing a little and to increase fuel enrichment and octane. These tips are critical when adding forced induction (turbos, superchargers or nitrous kits), and failure to address ALL of these areas will virtually guarantee engine damage.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby barryogen » Fri Mar 16, 2007 10:30 am
anyone dyno'd with the bump in compression? what difference did it make?
barryogen
2ZZ Guru in training
Postby pc » Fri Mar 16, 2007 11:12 am
barryogen wrote:anyone dyno'd with the bump in compression? what difference did it make?
On my bluetop it increased torque nearer the bottom of the rev range, it also made the car much easier to drive around on the road. It didn't seem to affect the peak power figure though.
red car
Manfield - 1:24s
pc
Postby ChaosAD » Fri Mar 16, 2007 12:39 pm
True, I went to the shop and they had platinum plugs listed as the standard replacements :? They were dearer than the iridium.
Copper plugs is what im after, so ill just try another dealer.One heat range sounds like all I need.
Bump in compression made it guttless as I had to retard the timing so much when using the standard ecu for ignition.but a high compression is needed to counter the large overlap in the cams im putting in.
ChaosAD
Postby EVLGTZ » Fri Mar 16, 2007 10:21 pm
ChaosAD wrote:True, I went to the shop and they had platinum plugs listed as the standard replacements :? They were dearer than the iridium.
Just ask for the copper equivalent of the platinum plug they detailed and 1 heat colder. It may not be listed in their books but its easy to work out which one is correct
EVLGTZ
EVLGTZ
Postby Dell'Orto » Fri Mar 16, 2007 10:36 pm
Big or small port? I think they're a BKR6E11 standard, so drop to a 7
Postby Caveman » Sat Mar 17, 2007 10:55 am
thats weird, the 4agze ones are platnium std but the 4age just use cheap copper or similar.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby AE82 FXGT » Sat Mar 17, 2007 1:06 pm
I've found NGK lists all 4ages/gzes as taking platinums.
But yeah I always use the copper equivalent and change them more often.
AE82 FXGT
Postby strap-on » Sat Mar 17, 2007 1:13 pm
have a look at the NGK website there is HEAPS of tech info there on spark plugs
strap-on
Postby crispy'86 » Sat Mar 17, 2007 6:52 pm
what lift are the spec for the cams Scott? Maybe pm me as i'm going to be doing the same in my fxgt soon, and i'll measure my cams for base circle and lobe on the cam
crispy'86
Postby ChaosAD » Sat Mar 17, 2007 8:57 pm
Cant really remember, bout 8.9mm or something. wouldnt be a 50hp increace so one heat range should do I guess.
I got some copper ones one heat range lower. Ill let you know how they go.
ChaosAD
