Stu- wrote:Are they all that reliable? I've heard nothing but bad stories about them. Bosch ones seems to super reliable.
NOLAW wrote:unsure on what fuel pump to get for ma 4agte, engine will be running standard ze fuel rail, 550cc injectors, new regulator etc. whata you guys reccomend. cheers
True-No-Turbo wrote:NOLAW wrote:unsure on what fuel pump to get for ma 4agte, engine will be running standard ze fuel rail, 550cc injectors, new regulator etc. whata you guys reccomend. cheers
And if your fitting a Walbro to an ae101 gtz, you have to grind the welds off the outlet tube and move it across so it lines up with the pump outlet as its on the opposite side to a stock gtz one.
IH8TEC wrote:True-No-Turbo wrote:NOLAW wrote:unsure on what fuel pump to get for ma 4agte, engine will be running standard ze fuel rail, 550cc injectors, new regulator etc. whata you guys reccomend. cheers
there are two different walborough part numbers, for that very reason, the outlets are on different sides
